Front fender... posessed?Front fender... posessed?I may get heaps of abuse for this question, but if anyone else has encountered this, I'd appreciate some insight, I'm stumped. I'm restoring a 1967 cb77 superhawk, and the front fender fit beautifully when it came off, and now sees to have changed shape somehow.
More detail: I removed the front fender without using force, gently tapped out some mild dents at the front tip and rear tip, buffed out some rust and repainted. The fender was off the bike for about 6 months while I went through the engine completely. When it was time to build it back up, everything went swimmingly until I had to reattach the front fender. I attached the center mounts and the front and rear stabilizers wouldn't line up. In fact they appeared to be about an inch too long. If I bolt up the stabilizers, I can just force the center mount into position, but the front and rear edges of the fenders are too far off the wheel, and it looks like the wrong part. The cable stays are in the right place, so it's not on backwards, and it did not get mangled in storage. And there's no way it's not the fender that came off the bike, it's the only bike I have! If I'm overlooking something obvious, or if anyone has encountered this, please enlighten me.
Re: Front fender... posessed?Did you replace the sliders?. .........lm
RIDE IT DON'T HIDE IT!
front fender?if you do turn out to have a fender for the steel sliders, and need one for the alloy sliders. I would like to trade my alloy version for your steel version. I am needing a front fender for the steel slider set up.
TIA Randy
