???????????6mm "special nut and sealing washer"
???????????6mm "special nut and sealing washer"Bolting case halves together on a CL77 and the books call for a special nut and sealing washer on one of the 6mm studs next to the oil pump outlet. Anybody have a pic of where this actually goes and what it looks like and if a standard nut with a shoulder and a sealing washer wouldn't work as well.
Thanks
Re: ???????????6mm "special nut and sealing washer"The nut is that tall one with the closed end and the washer is aluminum. ...........lm
RIDE IT DON'T HIDE IT!
Special nutsThat is NUTS
Thanks guys. I can make one now. What were they thinking? Just wanted to make a nut with a flat bottom to take a washer and that is what they came up with?
Re: Special nutsIt seals the channel where all the oil from the pump heads to the engine parts which need it. ..........lm
sealing nutI love those little Asian engineers. They think of everything!!!!
