Carb Float Adjustment Clarification
JC
Post by JC » Thu Jun 26, 2008 3:52 pm
I've read all of the posts regarding carb adjustments and especially float adjustments. I have two questions to ask just to clarify:
1. The float setting of 26.5 mm is measured from the surface that the bowl gasket seals against or, is it measured from from the top of the "lip" that surrounds the gasket?
2. Is the measurement made with the float valve spring fully depressed? (carb inverted)
I had my '67 CL77 running but it was popping through the left pipe and fouling the plug. I read where this indicates a incorrect float setting (too rich) and I've been trying to correct it but now I can't even get it started. I've gotten real good at taking my carbs on and off!
I need some advice before I bring out my shotgun! It's not even 2 O'clock and I'm getting deep into that six pack!!!
Thanks in advance for any help,
Jim Cain
kustommusic
Post by kustommusic » Thu Jun 26, 2008 8:17 pm
Jim, Are you sure the carb(s) are the problem? Check your points and timing adjustments too. Mabey you'll find it there and wont need the second 6 pack. Good Luck, Kustommusic
Phil-UK
Post by Phil-UK » Fri Jun 27, 2008 7:41 am
Hi Jim
I'd check your figures, pretty sure 26.5mm is for the CB72 carbs.
Phil
Re: Carb Float Adjustment Clarification
Post by LOUD MOUSE » Fri Jun 27, 2008 8:13 am
I have a simple way to set the floats on the CB/CL77 carbs. With the bowls removed and also the main jet I look across the bottoms of the floats and set the float tang to just touch the needle valve at the same time I just see the brass main jet holder. ...................lm
JC wrote:I've read all of the posts regarding carb adjustments and especially float adjustments. I have two questions to ask just to clarify:
Jim Cain
RIDE IT DON'T HIDE IT!
JC
Post by JC » Fri Jun 27, 2008 10:29 am
Kustommusic, I used Ed Moore's tune up guide, but I'll double check. Thanks
Phil, My Clymer's manual says 26.5mm for the CL77 and most of the posts here use that measurement. I'll double check that too. Thanks
Loudmouse, That sounds to easy to be true but, it's tricks like these that comes from years of experience that usually trumps the manuals! I'll get it done this evening. Thank you
Dogsbd
Post by Dogsbd » Sat Jul 05, 2008 3:23 pm
LOUD MOUSE wrote:I have a simple way to set the floats on the CB/CL77 carbs. With the bowls removed and also the main jet I look across the bottoms of the floats and set the float tang to just touch the needle valve at the same time I just see the brass main jet holder. ...................lm
Ed, does the above hold true for the CA77 carb as well?
If not, do you have a similar technique for the Dream carb? Please elaborate if so.
Thanks.
Post by LOUD MOUSE » Sun Jul 06, 2008 8:43 pm
Not sure as I don't have a DREAM carb to measure. Sorry. .................lm
Thanks.
