CB77 Rear Brake Cable
GregMcN
Post by GregMcN » Sat Sep 28, 2019 2:25 pm
Rear brake cable
Does anyone know how the pictured CB77 rear brake connector is attached. It looks as if it might be made in 2 pieces? threaded together? or just soldered on?
Thanks Greg
AlanW
Post by AlanW » Sat Sep 28, 2019 3:21 pm
Hi Greg,
I am pretty sure they are crimped, the groove is for the protective gaiter. The other end is soldered.
Cheers Al.
DJM
CB72 rear brake cable
Post by DJM » Sun Sep 29, 2019 5:40 am
Greg,
I think Alan is correct in that they were originally crimped and certainly the machined groove locates the outer 'bellows' sleeve.
I've made up several replacements by soldering on the end fitting with no problems, you just need to be confident in your soldering abilities and use the correct flux and solder.
Getting the old inner cable out of the end fitting can be a challenge, I found that heating up the end fitting (with the inner cable in place) to red heat destroyed the temper of the inner cable strands allowing it to be drilled out easily enough with a 3mm drill.
GregMcN
Post by GregMcN » Thu Oct 03, 2019 3:09 pm
Thanks Alan / Dennis, will have a go at heating and drilling to remove.
GregMcN
