Post
by pwdavis45 » Mon Mar 31, 2014 5:07 pm
I just finished a rebuild on my cl77 with .5 over pistons and new rings with a re-bore and honing. Engine started smoking (white out the exhaust) after warm up mainly from the right jug. I pulled a compression test after about a 30 minute engine run and the right cylinder was at 90 psi and the left at 120. I did the old oil in the cylinder test and both sides came up to 150. I feel I did everything right and measured and corrected the ring gap according to the instructions. Also positioning the ring gaps the right way and with the right side up. Am I not waiting long enough for the rings to seat? What else could be wrong. Need help...Thanks.
