im stuck during teardown. need cb77 flywheel puller
Have the flywheel off. cannot remove bottom trans caseI have the flywheel off after getting the tool on ebay. I have all the nuts off the bottom case 1/2 all the way around. quadruple checked. I have the oil pump out as well. I cannot separate the case 1/2's. I have used a rubber mallet for about 2 hours working my way around the case and it is not moving at all (engine is upside down as I need to replace 2nd gear or the shifting fork). I see no bolts or nuts in the way. is there anything I am missing?
I hadnt when I posted, then found this link:
http://www.honda305.com/forums/1962-cb7 ... 79-63.html and that resolved the issue. I have the bottom cover off and am comparing my parts to the donor setup I got on ebay. To me, one of my shifter forks is bent on one side. like its dented midway down. So i am reusing my bearings but putting the whole doner setup in as it has less wear. my case halves had no gasket between them but what looks like just a tiny layer of sealant. I had no leaks. I now see in my gasket kit there isnt one so do i put sealant on it? if yes, what type? what sealant for the case halves?I have the donor tranny & shift forks in and new seals. what case sealant do I use? I have cleaned the mating surfaces, but it looks like there were 2 sealants used. very light tan and in some spots black (it reminds me of the high tack aviation permatex)
what gives the best result?
