can't get the cam apart
Not loose any moreI used the center punch to tighten the rivets , then welded it one spot at a time and let it cool in between. I did'nt recall seeing a pic of this so I thought I'd put one up. It appeared to be the best place to weld. The curved sides of the sprocket base are closer to the chain.
64' CB77
65' CB160 Re: cant get the cam apart
Well guys, I'm pretty sure the neoprene is on the Rivet/pin at which the advance weight rotates. I didnt dissasseble this area to confirm it ( fearing that I would do more damadge by removing the rivets) but I tend to believe the expert when he tells me it's in there. It appeared to be the only place it could be. That said , I'm still rookie status.
64' CB77
65' CB160
