CB72 head??
hondaly
CB72 head??
Post by hondaly » Fri Aug 24, 2018 8:50 am
Hello Everyone, I have just built up my CB72 engine after a rebore, pistons etc. I used a different 72? head I had been given, fitted new cam bearings, ground in valves etc. I had measured the inlet port at 23.6mm and felt this was right for 22mm carbs.
On finishing the rebuild I realised the head had not been drilled and tapped for the "power jet" nipples for tube to air filters. Is this ok?? Was there a mod? Thoughts please.
Re: CB72 head??
Post by LOUD MOUSE » Fri Aug 24, 2018 9:04 am
The power jets which went to the filters came one from each carb.
Do you recall if the steel dome has a relief cast at the edg of the dome that went down a couple of mill or did the dome come sharp to the edge?. ..............lm
hondaly wrote:Hello Everyone, I have just built up my CB72 engine after a rebore, pistons etc. I used a different 72? head I had been given, fitted new cam bearings, ground in valves etc. I had measured the inlet port at 23.6mm and felt this was right for 22mm carbs.
hondaly
CB72 Head?
Post by hondaly » Sat Aug 25, 2018 5:37 am
Thanks for your reply Loud Mouse, I always read your posts with interest. Unfortunately I did not check the dome dia or whether it was chamfered at the edge. I thought because the inlet was 23.6mm it was for 22mm carbs and therefore a cb72 head. Is the inlet dia in the casting different for a 77 head? My old head had the drilled and tapped holes for the air vent joint/nipple, the passage seems to connect to the inlet valve guide. If it is a "72" head, can I use it without the air vent holes? I am trying to determine this without taking the head off ! I would be grateful for your thoughts. Al.
Re: CB72 Head?
Post by LOUD MOUSE » Sat Aug 25, 2018 6:33 am
The head without the 2 threaded valve vent holes came along sometime in late 66/67.
I'm not sure if the 250 had this or not so as much as I hate to tell you.
If that was my engine I'd remove and check the design of the dome.
Big difference in compression. ......................lm
hondaly wrote:Thanks for your reply Loud Mouse, I always read your posts with interest. Unfortunately I did not check the dome dia or whether it was chamfered at the edge. I thought because the inlet was 23.6mm it was for 22mm carbs and therefore a cb72 head. Is the inlet dia in the casting different for a 77 head? My old head had the drilled and tapped holes for the air vent joint/nipple, the passage seems to connect to the inlet valve guide. If it is a "72" head, can I use it without the air vent holes? I am trying to determine this without taking the head off ! I would be grateful for your thoughts. Al.
hondaly
Post by hondaly » Sat Aug 25, 2018 8:12 am
Thanks LM Yes I have decided to take head off and check dome. better done now than later. Al
Post by LOUD MOUSE » Sat Aug 25, 2018 8:38 am
Good on ya Al. ................lm
hondaly wrote:Thanks LM Yes I have decided to take head off and check dome. better done now than later. Al
