Post
by cknight » Fri Jan 18, 2008 10:00 am
If you've been trying to find a large bore head gasket for an S12 or 350-kitted (64mm) bore engine, Cometic Gasket (cometic.com) will custom produce the needed part. I sent them a sample, and in less than two weeks received the finished goods. This is a multi layered gasket with a proper fire ring installed (it will actually accommodate up to a 65mm bore). Quality appears excellent (as are any of their products I've previously used), and the price was just a bit more than the standard head gaskets seem to be going for nowadays. They assigned a stock number, H0157SP5043F, so that anyone can special order one. Regards, Chase
