High crankcase pressure
Loucip
Post by Loucip » Sun Jun 22, 2014 8:46 am
I have a 1966 Honda 305 Scrambler that has not been run for a long time. Recently I got it running and realized that for some reason the crankcase pressure is high enough to force the oil from any way possible from the crankcase.
conbs
Pressure
Post by conbs » Sun Jun 22, 2014 11:57 am
You might try searching this site. Make sure the gaskets/metal baffle are installed the right direction in the head cover. Also look at G-man's post under the "Piston Blowby" thread in this section.
Hamamatsu Nippon
Post by Hamamatsu Nippon » Sun Jun 22, 2014 7:10 pm
One other thing to check is the oil level. Make sure it is not overfilled with oil, or more likely, has had gas leaked into the crankcase.
1967 CA78
1965 CM90
Soichiro Honda
mike in idaho
Post by mike in idaho » Fri Jun 27, 2014 8:22 am
You could try putting an automotive power brake check valve in the end of the breather hose, or one of these reed valves from Mike's XS: https://www.mikesxs.net/product/15-0677.html
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
Re: High crankcase pressure
Post by LOUD MOUSE » Fri Jun 27, 2014 9:02 am
Have you checked the comprehension?
You may have stuck rings. ........lm
Loucip wrote:I have a 1966 Honda 305 Scrambler that has not been run for a long time. Recently I got it running and realized that for some reason the crankcase pressure is high enough to force the oil from any way possible from the crankcase.
