CLUTCH WIRE RING
STEVEUK
CLUTCH WIRE RING
Post by STEVEUK » Thu May 24, 2012 11:45 am
Hi all pulled the clutch plates out and according to the parts drawing there should be a wire ring between the first metal plate and first friction plate which it has but there is another 2 wire rings so i have 3 grooves in the clutch centre, is this correct and is the drawing wrong, and do these ring really need to be installed as mine are scrap as well as the plates.
Re: CLUTCH WIRE RING
Post by LOUD MOUSE » Thu May 24, 2012 12:07 pm
Add your location to your profile.
There were 5 different center hubs and you have the 6 plate issue. ..........lm
STEVEUK wrote:Hi all pulled the clutch plates out and according to the parts drawing there should be a wire ring between the first metal plate and first friction plate which it has but there is another 2 wire rings so i have 3 grooves in the clutch centre, is this correct and is the drawing wrong, and do these ring really need to be installed as mine are scrap as well as the plates.
STEVEUK
Post by STEVEUK » Thu May 24, 2012 12:17 pm
But do these wires need to be installed. steve
UNITED KINGDOM
Post by LOUD MOUSE » Thu May 24, 2012 12:20 pm
When ya do the early HONDA upgrade (change the thin first steel plate to the thick one) you can't install any of the wires.
Ya can get the replacement HONDA center hub which allows the thick steel plate and 2 wires. ......lm
STEVEUK wrote:But do these wires need to be installed. steve
