Starter not engaging
Sinkorswim
Post by Sinkorswim » Thu Nov 10, 2011 3:15 pm
I have been working on a 66 superhawk and after repeatedly starting the bike the starter doesn't seem to engage but spins... I pulled the covers of and don't really see anything broken... Obviously there is a problem... It just sounds like something is stripped.. This is my first 305 I have worked on.... Most of my experience is with newer Honda fours... These are tricky little bikes and any help would be greatly appreciated
Thanks
Chris
Re: Starter not engaging
Post by LOUD MOUSE » Thu Nov 10, 2011 4:19 pm
I suspect the springs which work with the 3 rollers at the rear of the rotor are bad and the rollers don't grip the starter sprocket when the starter motor spins the sprocket.
Pull the rotor and check. ...........lm
Sinkorswim wrote:I have been working on a 66 superhawk and after repeatedly starting the bike the starter doesn't seem to engage but spins... I pulled the covers of and don't really see anything broken... Obviously there is a problem... It just sounds like something is stripped.. This is my first 305 I have worked on.... Most of my experience is with newer Honda fours... These are tricky little bikes and any help would be greatly appreciated
Thanks
Chris
Sinkorswim
Post by Sinkorswim » Thu Nov 10, 2011 5:59 pm
so would the crank still spin if the rollers are bad
Post by LOUD MOUSE » Thu Nov 10, 2011 6:07 pm
The engine will always run/crank move no matter the rollers.
It's the system where the Starter Motor turns the Starter Sprocket on the crank. ........lm
Sinkorswim wrote:so would the crank still spin if the rollers are bad
Sinkorswim
Post by Sinkorswim » Thu Nov 10, 2011 6:25 pm
cool I will look into that when I get back to the bike later on this evening..... I have been married to this bike for the last 3 weeks... Also this is off subject but as for parts... where is the best place? In the future I plan on owning one of these and would like to know where I could readily find good parts... Dallas is kinda a black hole for old honda parts.
Post by LOUD MOUSE » Thu Nov 10, 2011 6:35 pm
I'm in KERRVILLE, TX. ...............lm
Sinkorswim wrote:cool I will look into that when I get back to the bike later on this evening..... I have been married to this bike for the last 3 weeks... Also this is off subject but as for parts... where is the best place? In the future I plan on owning one of these and would like to know where I could readily find good parts... Dallas is kinda a black hole for old honda parts.
Sinkorswim
Post by Sinkorswim » Thu Nov 10, 2011 8:05 pm
got it man... thanks for the help....
