Gas in crankcase
roadcapDen
Post by roadcapDen » Fri Oct 14, 2011 7:22 am
UPDATE...
Slides somehow (doh) got in the wrong carbs, I'll change them!!!
and put the needle clip at 4th from top as per Bill S and y'all.
And air/mix screw at 1 1/4 turns out?
Another questions if I may.
How to cut off a bit of the spark plug cables at the s'plug end and at the coil end just cut them off?
The s'plug end has a rubber boot and it looks like the inner wire is crimped over the middle/inside of the actual s'plug connector.
Thanks again...
roadcapDen
2 HD XL's
65 Dream 305
and a bunch of other scoots
Post by davomoto » Fri Oct 14, 2011 11:03 am
Twist and pull on the plug caps, and they will come off, normally. If you post a pic, it would help, as a PO may have put automotive type wire on it.
Davo
