camshaft removal frustrations
teazer
Post by teazer » Sat Feb 13, 2010 5:14 pm
Do not remove the guides unless you have the correct drift and plan on fitting new ones.
Just be very careful to was all the beads out.
For the combustion chambers I usually use a wire brush and the same on valves.
greg78gs750
Post by greg78gs750 » Sat Feb 13, 2010 5:17 pm
good, i really didnt want to take'em out anyway!! thanks. btw, there is 0 slop inthe guide-valve interface, so that is good...and they produce vacuum when i pull the valve out! pretty tight tolerances, there, i guess.
68Cb77
Post by 68Cb77 » Sun Feb 14, 2010 12:14 am
man, I had exactly the same problem when I rebuilt mine..thought I was going to beat the daylights out of that thing. I almost wonder if people torque that bolt too high when they put the camshaft back together.
67 Honda CB77 Superhawk
82 Honda XR200R
70 Honda CB750 K0
