original finishing of the cylinder and cylinder head
jensen
Post by jensen » Fri Dec 18, 2009 8:39 am
Hi chico,
If beat blasting a used cylinder head, it's only is more time consuming, but the results will be comparable,
jensen
rbaselt
Post by rbaselt » Fri Dec 18, 2009 8:40 am
After bead-blasting a used head/cylinder, if you spray lightly with a high-temp flat silver or dull aluminum paint, it looks very close to original. And after running (or baking in an oven) for an hour, the paint is very durable and provides an easy-to-clean surface. --Randall
jensen
Post by jensen » Fri Dec 18, 2009 8:46 am
Yes, I think it will be the same color, can you show us pictures to compare ?
The picture of the nos head (non-blasted) is to compare. Are you sure to use dull aluminum ?
As you can see on the pictures, the surface isn't dull, but shiny (not glossy).
rbaselt
Post by rbaselt » Fri Dec 18, 2009 10:12 am
I don't have any photos, unfortunately. But I have used this treatment on about 6 bikes that I restored, and it works very well. You don't want to use a bright silver or aluminum soray, since these are glossy and look "painted". The dull or flat sprays have a metal-like sheen when cured.
Randall
Hondac71
blasting
Post by Hondac71 » Fri Dec 18, 2009 10:33 am
The way i had my parts done is by vapour blasting, gets the parts shining like new and no paint required!
jensen
Post by jensen » Fri Dec 18, 2009 11:50 am
hoi jelle,
Wat is dat ?, hoe werkt dat ?
Heb je er ook foto's van ?
jensen
(hi jelle,
waht is it, how soes it work ?
so you have any pictures ?
Jensen)
