LOUD MOUSE wrote:<br />I only do complete engines. Labor is $250 plus $80.00 valve job, gaskets and seals $80.00, bore job was $110.00 last time I had one done and pistons and rings are depending on the actual size needed. (I have more of some sizes than others) I have perfectly good used or new parts here so can usually keep the cost down compared to what others ask. Most engines go out under $1,000. .......................LM<br />
<br /><br />LM, thanks for the info. I will keep you in mind.<br />Rick.
