Page 1 of 2
CB160 piston rings?
Posted: Fri Aug 26, 2011 1:46 pm
by kalchcliff
Hello all. I have a set of rings for my CB160. Part # 13020-028-020, .25 over. This set has six rings that look real close to fitting but everything I have found out about them shows for a Honda 90 single cylinder. Any info out there?
Posted: Fri Aug 26, 2011 3:32 pm
by davomoto
The center code 028 is for an S90. I don't know if they are the correct diameter or thickness for your bike. There must be a forum for the 160s, as they are quite popular as vintage race bikes.
Davo
Posted: Fri Aug 26, 2011 4:29 pm
by G-Man
Hi
S90 and CB160 are the same bore at 50mm. Model code for CB160 is 217. If the rings fit the piston and the bore then you should be fine.
Posted: Tue Aug 30, 2011 11:21 am
by kalchcliff
Thanks guys. Will proceed.
Posted: Fri Nov 11, 2011 10:37 am
by roadcapDen
The only forum I could find for CB160's was CA racers, not much there?
Posted: Fri Nov 11, 2011 11:58 am
by brewsky
Posted: Fri Nov 11, 2011 1:52 pm
by kalchcliff
Try F-160. CB160 racers mostly on the west coast. Lots of good info.
