Faulty Fuel Tap - petrol only from one outlet at a time ?
Posted: Sun Jul 31, 2016 3:33 pm
Hi
Anybody ever had a problem with the twin output fuel tap on a CB350 where petrol only seems to come out of 1 outlet ? Draining the tank direct from the tap outlets I get a good flow out of 1 outlet but not the other. Then if I block the good one off the petrol then comes from the other !!
The bike is only just back on the road after finally getting a registration doc ( originally came from the US ) and when I drained both carbs I definitely got more fuel from one than the other so I think its an issue when running.
I know its basically the same tap as the CB72/77s and if draining my CB72 both outputs flow the same.
any suggestions please,
Phil
Phil
