Hi
Anybody ever had a problem with the twin output fuel tap on a CB350 where petrol only seems to come out of 1 outlet ? Draining the tank direct from the tap outlets I get a good flow out of 1 outlet but not the other. Then if I block the good one off the petrol then comes from the other !!
The bike is only just back on the road after finally getting a registration doc ( originally came from the US ) and when I drained both carbs I definitely got more fuel from one than the other so I think its an issue when running.
I know its basically the same tap as the CB72/77s and if draining my CB72 both outputs flow the same.
any suggestions please,
Phil
Faulty Fuel Tap - petrol only from one outlet at a time ?Re: Faulty Fuel Tap - petrol only from one outlet at a timePhil
Probably an obstruction in one of the passageways. If you know someone with (or have one yourself) an ultrasonic cleaner I would give it a good session in there. G
'61 CB72 '64 CB77 '65 CB160 '66 Matchless 350 '67 CL77 '67 S90 '77 CB400F
