My buddy had a question regarding his bike
Posted: Tue Aug 03, 2010 8:14 pm
It's not a 60's honda, but he was hoping some of you would have some info for him as other forums haven't helped his search for info.
"Hey there guys,
First off, the bike is a 1974 Honda CB360 w/ not a spot of rust and only 6,000 original miles. This bike literally sat in an old mans garage for 30 years. I am the first to restore it. Never been dropped or taken apart. Each piece I take off this bike still has some of the factory plastic attached to it (seat, levers, etc..)
So here's what is going on and also what I've done.
Currently the bike idles, responds and drives really nice. There are no hesitations all the way up to redline on this thing. It seems to be tuned in really well and it's a fast little bike.
THE PROBLEM:
The right side exhaust sort of gallops and sputs a little at idle and if I drive it for about ten minutes, the right side stops running. Spark still goes on the right side, but I don't know what's making it stop running. The left side still runs great and strong and everything.
A few things about it and what I've done to restore it:
I have adjusted the points 3 times through troubleshooting/doubting myself. Spot on every time
I have cleaned the carb by dipping it in one of those cans of carb cleaner.
I rebuilt the carb with a kit w/ new jets, air screws and gaskets.
I Kreemed the tank.
I replaced the petcock with a NOS one.
I am 1.25 turns out on the air/fuel mix screw on both sides which I'm told is the stock setting.
I replaced the diaphragm on the right side carb. Both are nice and hole/rip free now. They both glide nice.
The bike has aftermarket pipes on it that look nice and everything, but seem to have less baffle than the original pipes did. Previous owner put them on.
I have aftermarket air filters on it, so I might be running a little bit rich but the problem I'm having currently is only in the right side and no amount of air/fuel screw turning is changing it.
SOLUTION:
I don't quite know what to do. I try to keep from assuming things are tuned right unless I've done it myself.
My last idea would be to check the valves. I have never done this before so I don't know if the problem I'm having could be caused by the valves being out of spec.
Help please? Ideas?"
from ryan via gun
thanks guys
"Hey there guys,
THE PROBLEM:
I Kreemed the tank.
SOLUTION:
from ryan via gun
thanks guys
