Thanks. I gave it a good try alreadym, but must be missing something.
Will work on it some more.
Chunk missing from engine case
It might be a plain type of retaining ring with no obvious way to spread it to remove it. Clean it well and you should see a small gap. If this is the case, you will need to get into that gap to lift one end and get it started out of the groove. A knife that you don't mind damaging the edge will probably do the trick.
Please take pics of what you find and post.
And go get yourself a can of BrakeKleen. It's degreaser with a high pressure propellant that will blast areas clean. Toothbrush is helpful as well.
regards,
Rob
regards,
Rob
