Have ya done work with the valves/cam?
Yes ya can remove the valve caps then put the rotor to "T" and see if either side had both valves are adjusted to .004 and can be wiggled.
If ya find neither side has loose valves that ya can wiggle then either your valves are to tight or the cams are not timed to the crank with the chain correctly. .........lm
acurtiss wrote:That's what I thought. So switching the wires around is a waste of time :)
Is there any way to check valve timing without dropping the engine?
