Need header pipe mounting bolts/skrews!
newcb77owner
Post by newcb77owner » Fri May 27, 2011 3:37 pm
I have the headers, the spacers, the gaskets, and the 2 mounts. BUT I do need the 4 bolts that are needed to secure them all to the engine. Please if you have and extra set, let me know. Or the size needed.
Thanks, Dan
Post by davomoto » Fri May 27, 2011 6:20 pm
6mm x 28mm stud is what the online fische says it requires. Most hardware stores have a small selection of metric studs, or you could use bolt of the correct leng. 6mm x 1.0 is the thread diameter and pitch.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
newcb77owner
Post by newcb77owner » Sat May 28, 2011 3:32 pm
Hey thanks for the info!
so what your saying it that the thread pitch is 6mm x 1.0? i don't care for length as long as i can skew em tight.
thanks again!
Post by davomoto » Sat May 28, 2011 4:05 pm
Yes, 6mm x 1.00
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
