CA72 best place for engine parts
jim milewski
Post by jim milewski » Thu Aug 21, 2008 7:03 am
Hi, new member and just found this forum. I tore down a Dream engine, the 250, the reason for the teardown was tons of oil coming out the exhaust, it appears that the O rings sealing the flow to the overhead cam failed. Anyway I need head and base gasket, valve cover gasket, exhaust donuts for the 250 engine, dealers are little or no help, any help will be much appreciated, there are probably other parts I will need as I start further dismantling. So is there a good place to get these older parts?
RANDY BECKER
Post by RANDY BECKER » Thu Aug 21, 2008 7:32 am
ohio cycle has every thing you need.
