CA77 Speedo Wiring
hondadreamca77
CA77 Speedo Wiring
Post by hondadreamca77 » Sat Nov 17, 2012 3:33 pm
On the schematic from this site it shows a brown wire going to one side of the speedo lamp...along with a ground.
My bike has a blue and green wire to two lamps under the speedo, I assume one is for high beam. What is the correct hook up of the green and blue lamp wires? I have everything else working. I was thinking of splicing the one directly into the headlamp circuit....short of info.
Thanks.
Post by davomoto » Mon Nov 19, 2012 9:08 am
Blue is high beam, and should plug in to the blue wire on headlight. Green is back lighting for speedo, and should come on with the headlight.
Davo
hondadreamca77
Post by hondadreamca77 » Mon Nov 19, 2012 11:10 am
Thank you.
