battery charging
joeweir1
battery charging
Post by joeweir1 » Sat Mar 20, 2010 8:37 pm
Feel dumb asking this but, would charging my battery on 6 volt setting hurt my battery at all?I accidently bumped the switch from 12v to 6 volt in the process of charging and did not see it till I checked to see the full charge light was on much later.joe
Post by davomoto » Sat Mar 20, 2010 10:36 pm
Joe, I must admit, I've done ythe same thing, and no negative effect. Much better than going the other way, 12v on a 6v battery!
Davo
Gunner_CAF
Post by Gunner_CAF » Sun Mar 21, 2010 12:25 am
No, I won't hurt it. It won't charge, but no damage done.
Gunner
joeweir1
Post by joeweir1 » Sun Mar 21, 2010 9:39 am
thanks.The full charge light was on when I discovered it, but then I did hook it back up and it did take awhile for it to actually charge.
jensen
Post by jensen » Tue Apr 27, 2010 2:03 am
It depends on the charger. When it's current driven, there will be no damage and the battery will charge, only slower. If it's a voltage driven, the battery wil not charge, and there's a change for damage of the charger (not the battery).
If it's a modern computerised charger, it depends on the brand or / and type if damage will occur.
Gunner_CAF
Post by Gunner_CAF » Fri Apr 30, 2010 10:15 pm
jensen wrote:Hi,
One should always include the "snowball's chance in hell" possibility just in case the person in question is still not confused.
