Starter woes...
Starter woes...Hey all! Total noob here, so I apologize in advance!
I just picked up a '66 CL77 in pretty good condition. When I was checking it out at the guy's house that I got it from, it would kick start on the first or second kick and could sustain a nice smooth idle for a good while. Acceleration was good and it would cruise perfectly at about 45 (didn't take it any faster than that.) Today after work, now that it's back home, I can't get the thing to start for the life of me! I kick and kick and it turns over, but never actually catches. The lights are also no longer working, in any switch position. I'm assuming that means dead battery (picking up a tender tomorrow, and probably a new battery) but could that be ALL that's wrong? I always thought that you could kick start even with a dead battery. Any thoughts? Thanks!
Hey Dave, welcome to the slightly barmey world of older Hondas.
The dynamo / alternator will output sufficient voltage and current, but if your battery is completely flat and / or with a shorted cell or two due to excess sulphate within, then it won't be able to overcome such a burden upon the system. AND, if you bump-start it and do get it running then you run the risk of damaging the rectifier. Check the battery voltage with a meter. If it has self-depleted to below 10V then it's shagged, in which case a replacement is called for.
Re: Starter woes...Are ya sure ya didn't turn the engine off with the key in the park position rather than the kill engine possition?. ........lm
RIDE IT DON'T HIDE IT!
Good call, LM! Although I'd think that the parking lights should've been apparent enough to be noticed that they were lit.
Dave, I should've added 'try externally charging the battery' to my advice.... NEVER run a 305 (or 247) with a totally flat batt; the originally-fitted selenium rectifier cannot asborb the current that a flat batt will demand of it. Don't run it without a battery, either; that will damage every electrical consumer on the bike, including the ignition system! In excess of 30V could be produced without a battery in circuit to 'cap' the voltage.
Happens all the time with new owners. ................lm
