CB77 Battery voltage dropping before my eyes...
brewsky
Post by brewsky » Mon Jan 23, 2012 12:02 pm
Sounds like you either have a bad battery or a short somewhere.
Disconnect the battery leads and test between them with multimeter set to ohms....if you have any reading with the key set to "off" position, you have a short somewhere in the hot circuit to the switch, (hot wire to switch, or rectifier)
If not, have your battery tested.
If battery checks good, then the short is after the switch.
Jlovvorn
Post by Jlovvorn » Sat Jan 28, 2012 5:53 pm
This was a defective battery.
Defective battery dropped down to 6-7 volts on turn of key.
New does not.
Battery less than two months old.
brewsky
Post by brewsky » Sat Jan 28, 2012 7:41 pm
Hope you kept the receipt!
Jlovvorn
Post by Jlovvorn » Sat Jan 28, 2012 7:44 pm
Crappy low bid fleabay.
Bought motto, and it seems great.
