starter button wire connection.
mike1969
Post by mike1969 » Sun Mar 06, 2011 9:27 am
I recently replaced the throttle cable on my Dream. When I took the assembly apart the yellow w/red stripe starter wire fell out. There is no sign of any solder or anyway to see how it was attached.
How do I attach the wire? Is it supposed to be soldered to the brass strip or attached to the screw?
brewsky
Post by brewsky » Sun Mar 06, 2011 10:36 am
It should be connected to a terminal which the starter button contacts to ground the wire. The terminal is insulated from everything else....it may still be in the housing
mike1969
starter button
Post by mike1969 » Sun Mar 06, 2011 11:52 am
Thanks Bruce,I'll take another look at it. Mike
mike1969
starter wire connection
Post by mike1969 » Thu Mar 10, 2011 9:08 am
Finally got it figured out. I went to Bike Bandit website which showed where the wire had to be connected. They have a parts manual with blowups and parts # of all sections of Dreams.
If anyone needs the blow ups go to bike bandit and look up 1961 Honda ca77.
