67 CA77 NO Spark
Huck
67 CA77 NO Spark
Post by Huck » Fri Nov 25, 2011 11:03 pm
Cleaned and reset point gap, checked and reset timing, Pulled both plugs and with fresh battery and plugs touching ground--cranked engine and got no spark. Plug wire boots are tight with clean connections. Battery connections are good. How do I test the coil, condenser, etc. for output?
Hotshoe
Post by Hotshoe » Fri Nov 25, 2011 11:16 pm
Check your fuse if you haven't already.
Huck
No spark
Post by Huck » Sat Nov 26, 2011 8:26 am
Fuse is good---I have 12V past it.
Hotshoe
Re: 67 CA77 NO Spark
Post by Hotshoe » Sat Nov 26, 2011 10:22 am
Huck wrote:Cleaned and reset point gap, checked and reset timing, Pulled both plugs and with fresh battery and plugs touching ground--cranked engine and got no spark. Plug wire boots are tight with clean connections. Battery connections are good. How do I test the coil, condenser, etc. for output?
Was it running before you did the described work?
Did you try starting it with the plugs installed?
Huck
no spark
Post by Huck » Sat Nov 26, 2011 10:45 am
It's a new purchase--I put it fuel (it leaked out the petcock) tried starting it anyway and got 1-2 pops but nothing close to starting. I pulled plugs (not fouled but old) and used a bit of spray starter---no reaction. Upon inspection the timing (I marked the plate before doing anything) was off probably 50-60 thousands of an inch for F=mark.
The bike was repainted several years ago (red to black) and the bike just looks verry original--doesn't have the typical buggered up bolt and screw heads etc. Only missing the left side corb cover.
I am heading out to the barn not with plans to go over ever electrical connection, ground, then check for juice coming out of coil to dist block for plug wires---cut back the wires 1/4" and try new test plugs for spark. Will update shortly~~~~Huck
Huck
NO spark
Post by Huck » Sat Nov 26, 2011 4:42 pm
POINTS---Don't know what brand but somehow they built up a film of something that totally blocked the path when closed. Hard to believe, I went over them with a point file and some fine sandpaper. Never saw any pits or build up but when I used an ohm gauge and got nada from the baseplate to the points condenser lead---I knew where the problem was. Perhaps some aftermarket POC --don't know but I probably filed on them 2-3 minutes before I saw a nice shine. Then when closed--we got spark. So I buttoned up the wiring, finished my clean up and put a new lower gasket into the petcock---put some gas in the tank and VAROOM!!! No missing, just that sweet rumble from a 67 Dream.
So now it onto adjusting the idle mix screw and the idle speed screw and it will be time to take it out for a little ride.
Thanks one and all for your input--it helped me stay focused on the symptoms and the final solution. Huck
pknopp
Post by pknopp » Sat Nov 26, 2011 9:41 pm
That's great. It's frustrating but I always keep reminding myself that I'll figure it out sooner or later.
cron
