Here you go:mike1969 wrote:If you could post a pic of the side cover maybe we could tell you what you have. I have a side cover in good shape. If you can't post a pic I could send you pics of mine and compare. PM me.
CA77 Dream Side Cover Differences?
Re: side cover
- IMG_0381.JPG (116.79 KiB) Viewed 1636 times
- IMG_0379.JPG (115.54 KiB) Viewed 1636 times
side cover
Looks identical to mine. the depth at the bottom of mine is very close to 2.5 in. Where is your clutch cable? Under the cover or straight down from beneath gas tank area?
Re: side cover
Right now the clutch cable is hanging down from the middle of the frame - the engine, which I've never seen mounted, is on my work bench. ;-)mike1969 wrote:Looks identical to mine. the depth at the bottom of mine is very close to 2.5 in. Where is your clutch cable? Under the cover or straight down from beneath gas tank area?
Of course the cable cannot be routed as it is with the slotted cover, so I'm guessing it will come out from under the gas tank area, as it is now, extend back a bit, then loop back to the right side case. Time will tell.
Thanks for that depth measurement; I'll see if mine is the same.
