I have a 1964 CA77E and need to remove the key switch assembly from the speedometer/headlight housing. I can't see the apparent way to go about this and would like some advice on how to proceed. Is there a special tool required? Thanks for your help!
Boz64
Remove key switch assemblyYou just have to remove the ring on the outside of the switch. You can try to find or make a C spanner or you can try gently tapping the ring undone with a piece of hardwood in one of the slots.
'61 CB72 '64 CB77 '65 CB160 '66 Matchless 350 '67 CL77 '67 S90 '77 CB400F Remove switch assemblyThanks so much for the tip! Made a tool and got it undone.
Boz64
