stalling
abert51
stalling
Post by abert51 » Thu Jul 18, 2013 10:34 am
my 65 CL77 is new top end, valves adjusted, and ignition is checked - all good and proper.. Engine starts fine and idles OK but "cuts out" at twist of throttle. timed it at TF mark and points in good condition. Any ideas on whats happening. Air leak? fuel not there Image
DONZIE
Post by DONZIE » Fri Jul 19, 2013 7:15 pm
When you say cuts out do you mean it actually kills
abert51
stalling
Post by abert51 » Tue Jul 23, 2013 12:46 pm
yes, the motor just seems to starve itself and it will die. Starts right back up though. Only very slow rotation of throttle will get the higher rpms. this is, of course no good for going up steeper grades as the maching will bog down. Thank you.
Re: stalling
Post by LOUD MOUSE » Tue Jul 23, 2013 12:59 pm
If you are at the bike call me.
I'll PM # to you. ......lm
abert51 wrote:yes, the motor just seems to starve itself and it will die. Starts right back up though. Only very slow rotation of throttle will get the higher rpms. this is, of course no good f#or going up steeper grades as the maching will bog down. Thank you.
