noise in my transmition
noise in my transmitionHello I have a 1968 scrambler, i feel like my transmition is making way to much noise than it should, also feels like it gets really hot. is this heat and noise normal
Please add your location, maybe someone near you can make the difference. Maybe a short introduction about yourself ? Maybe a short introduction about the bike ?, the history ?, how you got it ? any pictures of the bike ? A little more info doesn't heart, the way you ask this question won't solve your problem either. Did you read yourself in ? looked at an exploded view of the engine ?, did you try to locate the sound ? is there oil in the engine ? how does it look like ? The internet is a source of free information, but in the end it's all about the quality of the information you want / get. And in most cases the information you get is made of the same quality as the quality of how the questions is asked. One of the worst quality question is : the engine doesn't run, what is wrong ? And a good answer to that question is : It's broken, dump it or fix it. Well, I guess you understand why I don't try to answer your question. Why should I put more energy and words in formulating an answer then you put energy and words in your question ? Jensen assembly of Japanese motorcycles requires great peace of mind (Pirsig)
Hi I recently purchased the bike in Los angeles. The bike is in good shape and i have been slowly going through it,cleaning surface rust, tuning the carbs, replacing damaged parts such as the sealed headlight I also replaced the rectifier and battery to modernise the electrics a little
There is oil in the engine but i was thinking that an oil change would be a good idea. The noise seems to be mostly coming from the bottom end and is definatly not knocking. I read a little on here about the adjusting chain in there. I noticed the heat after i had taken the bike on the freeway and opened it up a little more than I had previously. I hope this provides a little more information, any advise or tips would be greatly appreciated. Cheers Joe Hi,
How hot is hot ? Oil in my engine is getting hot too after riding it on a high way. Does the engine sounds strange ? Is the kick starter still attached and working ? Does the kick starter shake while the bike is riding ? Jensen assembly of Japanese motorcycles requires great peace of mind (Pirsig)
