no key for switch cl77
G-GAURD
Post by G-GAURD » Sat Nov 20, 2010 8:44 pm
i'm currently looking at buying a 67 scrambler cl77 for resto/repair.i want to check out the wiring and see if there is power getting to the points and see if it gets spark.
there is no key to turn it on and when i plug in the battery the ignition switch would get power to different leads but nothing was comming out.
is there a way to jump those connections kind of like hot wirring
any help is great
brewsky
Post by brewsky » Sun Nov 21, 2010 6:14 am
I don't have a CL wiring diagram, but you should be able to cross the red BA or BAT terminal with the IG terminal and get power to the coil.
