cb77 piston ring thickness (compression)
pguzman
Post by pguzman » Sat Aug 13, 2016 7:31 pm
i have been having trouble sourcing rings for my 1962 CB77. the last two sets that I recieved have measured .070 thick (the compression rings). the old rings measure .058. Have there been two different thickness rings used over the years? I have 6 separate sets of pistons sourced before 1972 which all measure .058 Any info will be greatly appreciated!
sixtiescycle
Re: cb77 piston ring thickness (compression)
Post by sixtiescycle » Sun Aug 14, 2016 11:46 am
pguzman wrote:i have been having trouble sourcing rings for my 1962 CB77. the last two sets that I recieved have measured .070 thick (the compression rings). the old rings measure .058. Have there been two different thickness rings used over the years? I have 6 separate sets of pistons sourced before 1972 which all measure .058 Any info will be greatly appreciated!
Sounds like you have early C77 rings which were thicker than CB/CL rings. I'll check the thickness of the ones I have later and see if they are .070
Dick Johnson
'61 CB92
'63 domestic CL72 Type 2
'63 CL72
'65 CL77
'66 CB77
'67 CB450D
'71 SL350
'71 XS1B
Post by LOUD MOUSE » Sun Aug 14, 2016 11:59 am
Please give the numbers for the ring set you have.
If the middle numbers are 266 Dick is correct. ................lm
sixtiescycle
Post by sixtiescycle » Sun Aug 14, 2016 2:17 pm
I just checked the ones (C77) I have and they are in fact .070, checked CB rings and are .058. My C77 are all coded with the old system part numbers.
Dick Johnson
'61 CB92
'63 CL72
'65 CL77
'66 CB77
'67 CB450D
'71 SL350
'71 XS1B
