perry400 wrote:Hi
Have had the cylinders rebored on my CB 72, for 0.5mm oversize Pistons.
The Pistons feel tight in the bore, they move by hand but feel a little tight, the workshop manual states cylinder to piston clearance of 0.1mm (0.0039 in). Is this normal on fresh bore.
Thanks for any help in advance.
I bore and hone my own cylinders and go with .002" clearance measuring at bottom of piston skirt when using stock ART piston. I would not recommend more than .0025". You might hear some piston slap noise with .0039".
Tim
