Speedo trouble
maia
Speedo trouble
Post by maia » Sun Apr 01, 2012 10:41 pm
Just wondering if anyone has had this problem. I'm sure it's not a cable lube or routing problem but everything is fine up to 70MPH then the speedo needle swings over to the tach needle and stays there mostly , occasionally swinging back to 100 MPH then back to the tach needle. It will return to normal at about 40 MPH then the cycle repeates at 70. Sounds like I need to send it to the tach shop. '63 CB 77 by the way. Thanks for any help.
68Cb77
Post by 68Cb77 » Mon Apr 02, 2012 5:27 pm
I had a similar problem develop last year. I tore the speedo apart and fixed it all up. But it's still kinda doing what your's is doing, so I guess it's the cable. My cable is old and original, but has a bad kink in it, so I'm thinking it's the cable. They're kinda hard to find, as I can't seem to find any one doing a copy of that cable.
I goes what I'm saying is it would be easier to try the cable first, it's quite a job getting that speedo all apart.
67 Honda CB77 Superhawk
82 Honda XR200R
70 Honda CB750 K0
maia
Post by maia » Mon Apr 02, 2012 10:11 pm
Thanks for the response, I think I'll disconect the cable from the front wheel and straighten it out, hook it up to a drill and spin it up to 70 and see what happens. If it's fine then I'll look at the cable routing again. There must be a diagram of the proper routing somewhere.
