Starter gear knock/pin
zoom
Post by zoom » Sun Jan 06, 2013 3:57 pm
Seem to be missing a part. It's motor came to me in pieces. I have a 64 CA77. Trying to finish the engine up. I believe Iam missing pin or knock for the starting gear thats on the crank. There's a hole for one on the crank and the inside of the starter gear is a spiral track. Gear has to hook on something. But for the life of me I can't find it in the parts diagrams. Help! Got a part number or were to find it on diagrams. Thanks
OldStan
Post by OldStan » Sun Jan 06, 2013 6:49 pm
No pin for the starter sprocket. The hole is a lube hole for the bushing in the sprocket. Normally the sprocket is sitting still while the crankshaft turns. What locks it to the crankshaft when the starter turns is a set of rollers against the flange on the outside of the sprocket which are held down by light springs in small plungers. When the engine gets enough speed centrifugal force, pushes the rollers away from the sprocket.
The springs do break and/or get weak and keep the starter from engaging the the crankshaft.
63 CA78
zoom
Post by zoom » Sun Jan 06, 2013 8:22 pm
Oh........cool! I obviously hadn't a clue and never saw it explained anywhere. Thanks a bunch. Now something more to check out.
