Fixing Cracked Side Panel
Rickytic
Post by Rickytic » Mon May 14, 2012 11:05 am
Mig will also work, put a paddle behind the area to be welded, tac it high, then low, then high, and continue until the tac meets in the middle.
If you really want it done to look the best, you will have to grind the weld, surface the area smooth with grinders, sanders, files, sandpaper etc. sand the entire piece, or sandblast it after you weld, then prime, sand and paint.
cknight
Post by cknight » Mon May 14, 2012 12:01 pm
TIG would be best. Also, weld a doubler inside for additional strength. Regards, Chase
Quinn
Post by Quinn » Tue May 22, 2012 1:52 pm
try calling a repair shop that does car exhaust and ask if they can TIG it for you tigging it will cause zero to no warping if done right. but its a very easy fix, nothing to be worried about
