I have a 1964? CA78 Vin CA78 1000050 and CA77E 1000050. I took it apart and cleaned it a year ago and it is now slipping. It has 5- 4mm friction discs and 4 steel discs. The friction discs range from 3.79 mm to 3.86 mm and the steel discs range from 1.54 to 1.59 mm. I am thinking that the friction discs should be replaced. There are several combinations of friction and steel discs, using 3 or 4 mm friction discs. I do not know which combination is optimum. LM would you please guide me?
Raceman
CA77 ClutchCA77 ClutchI stand corrected. There is a 5th steel disc still in the basket, held in place by the wire. It is thicker than the other 4.
Raceman CA77 ClutchI just spoke with LM ,he explained reality to me and is sending me the parts to fix my clutch. He is a great resource for the 305 community.
Raceman
Re: CA77 ClutchThanks Raceman. ...........lm
