CL77 CLUTCH DRAGGGGGGGGGGG
jcspc
Post by jcspc » Fri Aug 06, 2010 7:02 pm
Well. I've got my bike up for sale and was going over it today to make sure all is well after the 3rd or so re-assembly. The last time I had the bike together, it ran like stripped monkey on a grease ball with green tornadoes chasing it... it ran reeeeally good. Well, I took it out today for the first time and found the clutch to be dragging. I have the cable adjusted properly at the lever, top of the case and the adjustment screw on the side case with the lock bolt. It shifts ok but when I come to stop the bike still wants to roll and I can't put it in neutral like I used to do. I can't roll the bike backwards either. If I adjust the cable tighter, the clutch will slip. The lever tension is good, not tight or loose.
Am I missing something?
65' CL77 OWNER
