Dream Brake maintenance
Bob750
Post by Bob750 » Sat Apr 20, 2013 11:42 pm
Where in Bill Silver's Dream literature is the info on how to overhaul the brakes? I can't seem to find it and I'm not sure of the proper way to remove/replace the shoes.
Thanks in advance!
Bob
Had: '75 CB550 K, '79 CT90
conbs
Brakes
Post by conbs » Sun Apr 21, 2013 12:12 pm
Front and rear are different. It has been a while since I did it, but what I remember is gently prying the hinge apart and over/onto the retaining lip. Clean the back side of the cam and drive it through the backing plate while you pry the shoes up off of the backing plate. IIRC when the pressure is off the springs, the shoes can be twisted off the springs easily. Reassemble in reverse order. Probably not a Honda authorized method, but it worked pretty well.
cron
