Oil questions
bsanorton
Oil questions
Post by bsanorton » Sat Sep 19, 2009 8:46 am
Hi guys! New to this forum. Just picked up a 63' CB77. I haven't gotten a manual yet. Can you tell me where the oil drain plug is? Where the oil filter is & what type of oil to use, 5W30? Any manuals for free downloaded online? Thanks, Rich
Gunner_CAF
Post by Gunner_CAF » Sat Sep 19, 2009 10:14 am
The oil plug is under the engine, be careful not to bust off or strip any screws. I did this and it took a lot of work to fix. The filter is a bit different, it's a rotary filter that can be accessed inside the left side engine cover. It would be good to look for posts here about the filter. There is a thrust bearing that needs to be put in the right location to prevent damage. For oil, I use what LM suggests, 30W Non-Detergent. I found this at NAPA.
Gunner
bsanorton
Post by bsanorton » Sun Sep 20, 2009 8:45 am
Gunner, when you say 'screws' plural, is it the one large bolt dead center or the plate that has many screws holding it on (sort of like on Tridents)?
Goodysnap
Post by Goodysnap » Sun Sep 20, 2009 9:49 am
The large hex plug is the oil drain plug. The smaller 10mm Hex screws retain the oil pump into the lower crankcase .
64' CB77
65' CB160
bsanorton
Post by bsanorton » Sun Sep 20, 2009 9:59 am
Goodysnap wrote:The large hex plug is the oil drain plug. The smaller 10mm Hex screws retain the oil pump into the lower crankcase .
Thanks Goody, still looking for a decent priced manual!
Goodysnap
Post by Goodysnap » Sun Sep 20, 2009 10:37 am
Buy the Bill Silvers manuals from this site. Restoration and Engine manuals . Information inside is worth every penny. Use the search at the top to find topics in categories that might have allready been covered. But the manuals will help you out a ton. They did for me.
64' CB77
65' CB160
Vince Lupo
Post by Vince Lupo » Sun Sep 20, 2009 6:15 pm
Don't know if I'd be asking what kind of oil to use around here -- that is a dangerous subject!
