ca 77 carb rebuild kitca 77 carb rebuild kitG"day who's the parts guru on the forum to purchase carb rebuild kit? thanks , I noticed a wide spread of prices over the net thought I would keep it here along with other parts i will need thanks New guy LINY
Re: ca 77 carb rebuild kitCA77 carb.
If the bike is running I recommend you reuse all metal parts you have and get a new bowl gasket then do a good wash job. .................lm
Float bowl gasket and rubber gasket under the top cover. There are two different float bowl gaskets. Early 'round bowl' and later 'square bowl'.
http://4into1.com/rounded-float-bowl-ga ... cb72-cb77/ https://www.davidsilverspares.com/CA77- ... rt_230783/ https://www.davidsilverspares.com/CA77- ... rt_230806/ G '60 C77 '60 C72 '62 C72 Dream '63 CL72
Honestly that was one of the first things I did about a year and a half ago to the bike. Having issues getting it started right now actually. Im going to do the tuning guide thing tonight now that I got the slide to go all the way down in the carb. Starter doesnt seem to work so on the upside is I am getting used to the kick start lol. This was my first carb to work on so me not double checking sizes is possible.
~James
