A strange one
Merz64cb77
A strange one
Post by Merz64cb77 » Sat Jul 21, 2018 7:35 am
I’m no expert but I think it’s an electrical issue of some kind. Could it be a grounding issue?
Are you running NGK D10HS plugs?
67' CB77
66’ CB77
65’ bomber
68’ hellcat
malcolmgb
Post by malcolmgb » Sat Jul 21, 2018 4:08 pm
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
mike in idaho
Post by mike in idaho » Sat Jul 21, 2018 4:57 pm
You may still have a fuel/air issue. It should be harder to start without the choke. Is the air filter new? Have you tried running it without the air filter?
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
PF1
Post by PF1 » Sun Jul 22, 2018 4:23 pm
When I was a young chap my C72 had this problem after reassembly, the cam was one tooth out.
Kept fouling plugs tag lag. I was sure I had assembled it correctly too doh!
modelman
Post by modelman » Sun Jul 29, 2018 1:56 am
PF1 wrote:When I was a young chap my C72 had this problem after reassembly, the cam was one tooth out.
I hear what you're saying & I did think you could be right, but thinking about it, since the points-cam is on the camshaft, one tooth out would make the lobe around 10 or so degrees out & my points & backplate are in the exact position, & i'm sure the timing is spot-on as it was timed using the test-lamp.
Put in a pair of new iridium plugs & it ran great!!
'Correct' plugs in & no-go, so I bought a plug-tester the other day & found that over half of the many plugs I have are dud, took the 2 'new' ones I bought for the 77 back to the shop & they replaced them, the bike runs well now with the correct plugs.
I remember just how quiet these were in the day, mine is a bit noisy at the top-end, the gaps are correct & there was no evidence of wear, but I did use the old chain & tension-wheel,
so maybe that's the reason.
GSX1400 Red/silver
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
