Gear wear?
oldbikedude
Post by oldbikedude » Fri Sep 08, 2017 6:09 pm
Looks like that dog has some grinding marks like someone tried to touch it up at some point.
'67 Ca77 Dream
AlanW
Post by AlanW » Sat Sep 09, 2017 3:26 am
Is the shaft ok in the area that the rollers run on?
GORDON BROWN
Gearbox damage
Post by GORDON BROWN » Sat Sep 09, 2017 6:39 am
Hello Greg
From the picture it looks like it has possibly been welded up then ground back to shape ? Hardly worth putting it back in if you are going to put some miles on it. Unless you are in a rush to get it rebuilt. I don't have the experience with these gearboxes that some of the other forum members have but I do know damaged gears etc don't get better with use. As Alan W has said check the kickstart shaft where the countershaft rollers run on it as even slight wear can be the start of problems.
Gordon
SAFOJ
GregMcN
Post by GregMcN » Sat Sep 09, 2017 1:55 pm
All
I tend to agree that someone has tidied up the gear dogs with an angle grinder but do not think welded though I will have another look with that in mind.
I did not notice much wear associated with the rollers/kick start shaft but will have another look. The obvious wear is on the bushing at the other end adjacent to the kick start pawl.
Greg
Wear /damage on bushing
P1060665 (800x600).jpg (253.92 KiB) Viewed 3760 times
Post by G-Man » Sat Sep 09, 2017 2:35 pm
Greg
I think it would be good to get replacements for those parts tp give you a good start with your rebuilt engine. I am away for a couple of weeks but will happily look through my spares when I get back if you haven't found anything by then.
GregMcN wrote:All
Greg
GregMcN
Post by GregMcN » Sun Sep 10, 2017 2:51 pm
Thanks G for the advice and the offer, much appreciated.
I will let you know how I get on.
Greg
GORDON BROWN
Gearbox damage
Post by GORDON BROWN » Wed Sep 13, 2017 10:41 am
Hello Greg
If you cant get, the parts you are looking for from G-man or closer to home, I think I should have them ( though no spare kickstart shafts unfortunately ).
Gordon
SAFOJ
