Stripped Screws on right Crankcase Cover
cknight
Post by cknight » Sun Aug 27, 2017 5:47 pm
The folks at jdvproducts.com have a set of Vessel 5/16 hex drive impact bits for #2, #3, and #4 JIS, plus a straight slot bit. The kit part number is 431801, for about $11.00. You'll be surprised at what they can loosen. Regards, Chase
Tim Allman
Post by Tim Allman » Mon Aug 28, 2017 1:55 pm
This discussion makes me wonder if these screws are easier to come by than I think. I have been carefully replating and polishing my screws but would happily replace them if I had a source. Is there one?
jkv357
Post by jkv357 » Mon Aug 28, 2017 2:21 pm
It may be a little late for this for you, but I like to try to spin the screw out with a small chisel right on the edge.
The combination of tapping and the leverage out on the edge will usually break it free.
You do have to be careful to not touch the cover as you try to spin the screw, and it will occasionally slip off, but I've removed a lot of seized screws that way. You can also add heat.
revlover
Post by revlover » Tue Aug 29, 2017 2:44 pm
Tim Allman wrote:This discussion makes me wonder if these screws are easier to come by than I think. I have been carefully replating and polishing my screws but would happily replace them if I had a source. Is there one?
http://www.classichondarestoration.com/ ... -cb77.html
Is this what you're wanting?
Post by LOUD MOUSE » Tue Aug 29, 2017 3:58 pm
Your way is exactly what I do. .................lm
jkv357 wrote:It may be a little late for this for you, but I like to try to spin the screw out with a small chisel right on the edge.
