Showing off my Dream
Thanks for the info ! Is there excess cable tucked away ? I don't have the "flat" bars. I have a set of CB400 bars waiting to go on and they have a slight rise. Thanks again. The brake cable has quite a bit of slack.
The clutch cable on the other hand is just right for my bars. You could probably get away with the same but it might be a bit tight. The hardest part is getting the cables to route into the holes in the fork assembly. There is a pretty tight bend from the perches to the holes.
