sarals
Post by sarals » Thu Jun 22, 2017 12:20 am
Thanks, guys! I knew there would be resources here. I so appreciate it!
1965 CB77 305 Super Hawk
1989 NT650 Hawk GT
1981 Yamaha XJ550 Seca
Post by G-Man » Thu Jun 22, 2017 1:47 pm
Hi Sara
Nice to have you back. Just so that we can do some thinking with you, what have you actually got at the moment.
Podtronics rectifier - regulator?
Low output rotor or high output?
Have you tried a different rotor?
I still need to try re-magnetising a rotor. It sounds pretty easy....
sarals wrote:Thanks, guys! I knew there would be resources here. I so appreciate it!
sarals
Post by sarals » Fri Jun 23, 2017 10:09 am
Hi Graham!
It's good to be back!!!
I see you're still working on that CB72. That bike will be a museum piece when you finish it!
To answer your questions:
1) I have a Podtronics, new in the box. It's waiting for a higher output stator.
2) My rotor has the L stamped on it. The stator is the original. Are they high output? Apparently not, they won't keep the battery topped off.
3) Yes, I have. The rotor in the bike right now is not the original. I'm tempted to try another one, too!
Let me know if you find a way to remagnetize a rotor! I did see a video on YouTube a while back where a fella remagnetized a Triumph or BSA rotor while it was on the bike by hooking a high output battery charger to the stator and energizing it briefly. That was intriguing!
It's good to hear from you!!!
G-Man wrote:Hi Sara
1989 NT650 Hawk GT
sarals
Post by sarals » Fri Jun 23, 2017 12:48 pm
I'm curious, is the CL72/77 rotor and stator interchangeable with the CB72/77?
1989 NT650 Hawk GT
Post by G-Man » Fri Jun 23, 2017 1:15 pm
Hi Sara
In my CL77 parts book the rotor is listed as a 268 number, so same part.
sarals wrote:I'm curious, is the CL72/77 rotor and stator interchangeable with the CB72/77?
Post by LOUD MOUSE » Fri Jun 23, 2017 1:21 pm
The 180 crank engines used the CB72 then the CB72 (L) after that.. ..................lm
sarals
Post by sarals » Fri Jun 23, 2017 1:48 pm
HI LM!!!!
I was hoping to hear from you!!!
Thank you, my friend!!
LOUD MOUSE wrote:The 180 crank engines used the CB72 then the CB72 (L) after that.. ..................lm
1989 NT650 Hawk GT
